Mornin'. Big rain and snow thaw here. Unfortunately our sump pump ground fault kicked off and we had 15" of water in the basement.
Got it pumped out. It's an unfinished basement so it's just, (I say just) appliances that are at risk. Got the furnace dried out and running. Dehumidifier has all it's electronics up at the top, so it was o.k. Took the bottom of the gas hot water heater apart and put a space heater and fan on it. Got it pretty much dried out and running. I'll need to leave the space heater and fan on it for awhile to dry out the insulation so it doesn't rust the tank. Washer has it's electronics up high too so it's up and running. The dryer, is DOA. It was buzzing, Which is what alerted us to the problem. And the empty deep freeze was floating, and is toast also. Both the freezer and dryer were on their last leg anyway, if there is a silver lining to be found. Looks like I'm off to find a new dryer. Freezer, maybe, but it's empty 1/2 the time so we will see if that gets replaced or not. Maybe with a smaller unit if at all.
Never a dull moment.
