Supercharged Completely Polished Aluminum 540 Hemi Engine
MikeC6641
Postby MikeC6641 » Tue Apr 23, 2013 2:21 pm
This 540 Aluminum Hemi engine is built for pro street or the racer who wants the horsepower and durability of a race engine and the drivability of a street engine. This Hemi is a fully water-jacketed motor with a hydraulic roller streetable cam shaft, the compression ratio is setup for pumped gas and comes with dual 850 Demon blower carbs. Makes 850 Horse at 6400 RPM's on pumped gas.
This Aluminum Hemi is a completely polished version, for Show car, Hot Rod, Muscle car or Boat.
Hemi has all-new Components including:
Keith Black Street Polished Aluminum Hemi Block w/ steel sleeves and cross bolted mains (4.500" bore)
Mopar Polished Aluminum Hemi Cylinder Heads
Mopar Polished Aluminum Valve Covers
Crankshaft forged 4340 Nitrided Stroker (4.250" stroke)
4340 H-Beam Connecting Rods
Manley Intake stainless steel 2.25" Valves
Manley Exhaust stainless steel 1.94" Valves
Crane Hydraulic Roller Camshaft
Crane Valve Springs Double Springs with Dampers
Crane Chrome-Moly Performance Spring Retainers & Hardened Keepers
Crane Hydraulic Roller Lifters
Crane Push Rods
JE Pistons Lightweight forged 7.75:1 Compression Ratio (4.500" bore)
Intake & Exhaust Rockers Roller Tip
Keith Black Gear Drive Assembly & Polished Aluminum Front Timing Cover
Moroso 8 quart Aluminum Oil Pan
Keith Black Polished Billet Aluminum External High Volume and Pressure Oil Pump
MSD Electronic Billet Distributer
The Blower Shop Polished 8-71 Supercharger & Drive Components
Polished Aluminum Scoop with Air Cleaners
Additional Components:
- 1/2" head studs
- 9/16" main studs
- 1/2" side bolts on main
- Heavy-duty performance engine bearings
- SFI approved racing vibration dampener
- Precision balanced engine assembly
- Performance gaskets
- Set up for external oil filter
- 1" diameter oil pump feed line
- Moly performance rings
- Billet aluminum rocker stands
- Hardened performance rocker shafts
Price: $36,000.00
Contact: Mike at mikec55@rocketmail.com
Re: Supercharged Completely Polished Aluminum 540 Hemi Engin
Postby draglist » Tue Apr 23, 2013 8:54 pm
Looks amazing. bp
Postby Zappy » Sat Nov 02, 2013 5:27 pm
In the words of the great one....HOW SAWEEET IT IS!!!!!
Last bumped by MikeC6641 on Sat Nov 02, 2013 5:27 pm.
Users browsing this forum: No registered users and 44 guests
