An NHRA Event With No JFR
Postby Gator » Sun Apr 01, 2007 1:40 pm
It's virtually impossible to eliminate tire shake, and believe me, I've felt it.
( often couldn't hear for minutes after.),given the present tires/power,etc.
Sensors, etc. , all good ideas...
unless mandated higher tire pressures ( tougher to shake a spinning tire)
or a smaller (shorter sidewall)...well.......
Mtn.man
Postby Mtn.man » Sun Apr 01, 2007 3:31 pm
have an associate that raced P/M for years never wore a mouth pc. and now has no teeth of his own due to shake..
also what gator said, next to impossible to eliminate without changing tire issues...
seems if we can stutter electronics we can sensor tire shake...
great post WC and BP..
Walk softly, carry a Big Gun
and Thank You Troops!
Postby draglist » Sun Apr 01, 2007 7:18 pm
Bob Nevins had a great comment on one of the yahoo groups, where he offered much more detail about an actual device. I'll see if I can find and copy that here. bp
Find and edit our listings for your favorite racers!
http://www.draglist.com/draglist/search.php
Postby draglist » Sun Apr 01, 2007 9:44 pm
As promised, Bob "Speedy" Nevins' take on the deal, reprint authorized by Bob. bp
TIRE SHAKE +
I think Barry and I discussed this years ago about the different outlook on roll bars/padding between the NHRA and SCCA. Having done both for years and over on my head a couple of times, I have to say that I disagree with the whole NHRA/SFI theory. Think of a Bell. What makes it ring? The clangor/ball, that swings from side to side and strikes the outer bell shell, thus setting off a strong vibration. In SCCA road racing the driver's head is kept clear of all hard roll bars etc. He is protected by them but not subject to banging his head against them. This has nothing to do with a Hanes/neck collar/helmet restraint system. That is a good thing, for all the right reasons. Strong monocoque aluminum seats with padding and high backs and sides (like I had in my both my Willys) add safety. The six way driver's belts and arm restraints all pull the driver down to the chassis vibrations, and allow him to be a "Tuning fork", transmitting the cars vibrations. I know most of you guys have not had the experience of the tremendous/violent G forces generated by a blown fuel car. The extreme violent tire shake is part of it. I fought with it in my old fuel funny car and never really cured it. We just raised the tire pressure a bit so at a certain point the tires would break loose instead of running square and shaking.
I will share with you one of my "features" in my Safety/Econo car that I designed. I designed a "Tilt" type device, mercury switched master cut off switch. So in the event of a roll over,(anything more than 45 degrees), it cuts the power/kills the motor and prevents fires/shorts. A circuit breaker/fuse in an electrical system, disconnects the power when a abnormal surge occurs. What not a "Vibration Circuit Breaker"? At a preset level of it would just shut the power down. This would force the crew chiefs to tune the cars so that they launch smoother or blow-off the tires in smoke. 8,000+ horse power and 5 lbs. air pressure in flat-bottomed sticky slicks says, something has to give or shake sooner or later.
Back to the NHRA/SFI roll bars/padding...Have the same spec cage but move it slightly away from driver contact. Another one of my safety features in my Econo/Safety car is the removal of hardware. In a street car accident, what hurts the people inside? Banging around on window cranks, door handles, rear view mirror, etc. My car uses good old Velcro to raise and lower the shatter-proof Mylar side windows (like the old MG sports cars). Can't break you arm against something if it isn't there to hurt you. KISS
Yes, there is a need for improved, thicker/energy absorbing seats and helmets. Also maybe just cut the power/size/speed of all the Pro cars and take 90% of the risk factor out of the equation. KISS "Speedy" On the soap box again. LOL
Barb
Postby Barb » Sun Apr 01, 2007 9:48 pm
Domenic got tire shake once so bad that it knocked him out .. have it on tape and Bret will back me up. We were racing an IHRA event at Milan. Somehow, thank God, it also knocked his foot off the throttle pedal and it just idled down the track. The rescue personnel reached in and shut the fuel off and got the paramedics to him as quick as possible.
Postby Gator » Mon Apr 02, 2007 9:18 am
Barb, Thanks for sharing.
Tire shake is brutal ( as you saw)
The torque #'s we used to try to hit our cars with was immense. (rivaled T/F usable torque)..the only reason I'm commenting on this is from experience... and I'm not skeptical in the least about how severe "down track shake" ( and its affect on one's brain) is with 8000 plus HP.
Pro Drag Racing's a tough business , if it was easy everbody who watches would do it.
More gadgets?..That I'm skeptical about........
racersforcoffee
Postby racersforcoffee » Mon Apr 02, 2007 10:02 am
I want to thank everyone for sharing the emotional load during what is such a critical tech. challanging period. My forte is socio.; I can only point at the Brit. and Breedlove LSR research of the past 15 yrs and ask whether they would have any data to share on the shake problem re solutions 1/4 mile peeps don't have easy access to..... :(
The Free Market Of Ideas Works Both Ways
www.racersforcoffee.wordpress.com
morebetter99
My small photo tribute to Eric Medlen...
Postby morebetter99 » Mon Apr 02, 2007 1:47 pm
:cry: :cry: :cry:
http://www.slide.com/r/qP3DPIKctD8basML ... bedded_url
If you click on a photo when the slideshow starts playing, they become larger. If this sucks, let me know and it's gone...Pete
Postby pro70z28 » Mon Apr 02, 2007 1:53 pm
I think it's well done Pete. Thanks.
Postby jim sanders » Mon Apr 02, 2007 2:22 pm
Very nice Pete thanks !
