70 mustang traction
chevyv8_power
70 mustang traction
Postby chevyv8_power » Tue Apr 01, 2008 1:32 pm
What do you recommend for suspension upgrades/add-ons to get traction with a 70 mustang convertible? Would like to keep leaf springs to keep costs down. It has air shocks right now. Are these OK for drag? We are adding 26x10 slicks.
Postby Billy Mac » Thu Apr 03, 2008 10:07 pm
If you want to keep the leaf springs, the cheapest add on that actually works pretty good is a set of Lakewood style slapper bars.....bolt 'em onto the lower side of the spring perches and make sure that the snubber is all the way tight up against the front spring eye (no gap between the rubber snubber and the spring)
At a later date, you "may" want to consider stepping up to a ladderbar. This CAN also be used with the leaf springs, but a housing floater would need to be installed as well, to keep the bars and springs from binding up.....
Good Luck! 8)
Postby Eric David Bru » Fri Apr 04, 2008 12:56 am
IMO, you need a good set of slapper bars, drag shocks 90/10 (this is a strip car right?) and trick front springs.
What you want is weight transfer and the avoidance of axle wrap/wheel hop.
injected sidekick
Postby injected sidekick » Fri Apr 04, 2008 9:20 pm
Personally - If your looking for a cheap/easy fix the "slapper bar" would fit the bill. The slapper bar technology is a little dated. If your looking for better performance I would look into a more updated traction device. The newer devices give you a little better/lower ride height also.
The Cal-Tracs system is a lot better deal, in my opinion it is the best choice for street/strip and performance. The only downfall is if your street driven your going to sacrifice some ride quality. Here is a link http://www.calvertracing.com/
Slide-A-Link by competition engineering would be my second choice. It works on the same design as the Cal-tracs but it has a slide adjustability built into it to detune it for street or strip usage for better ride quality.
Here is the link http://www.competitionengineering.com/c ... Code=13116
If your a build it yourself kida guy, here is a link how to "copycat" the Cal-Tracs http://www.hotrodsandhemis.com/Traction.html
BTW ..Hello Eric :wink:
enjoy Jeff
Last edited by injected sidekick on Fri Apr 04, 2008 9:41 pm, edited 1 time in total.
Postby draglist » Fri Apr 04, 2008 9:38 pm
Welcome to the group and thanks for the info. bp
injected sidekick
Postby injected sidekick » Fri Apr 04, 2008 9:43 pm
Thank you Bill, happy to be here. :wink:
Postby Eric David Bru » Fri Apr 04, 2008 10:43 pm
Jeff
Hi Jeff,
I saw your username and thought that was you!
Users browsing this forum: No registered users and 22 guests
