NEW!! Push Rod & Wrist Pin Checking Tool
MikeC6641
Postby MikeC6641 » Tue Apr 23, 2013 2:18 pm
Billet Connection's NEW!! Push Rod & Wrist Pin Checking Tool @ http://www.billetconnection.com/tools_page.html
This Push Rod and Wrist Pin Checking Tool is designed to check the run out and straightness of both Push Rods and Wrist Pins of all sizes. This tool will accept push rods up to 13” long overall length and is adjustable to fit any length shorter than 13”.
This Kit comes complete with complete billet fixture, Dial Indicator, Wrist Pin V Blocks, 2 each 5/16” Cup Ends, 3/8” Cup Ends, 1 each 5/16” Ball End, and 3/8” Ball End. This allows all makes and models of Push Rods including Hemi engines, weather they are ball or cup type ends to fit into the fixture. The push rod stand is spring loaded for easy and quick push rod installation and checking. The dial indicator will flip up out of the way to make it easy to check wrist pins.
All billet aluminum parts are clear anodized for easy maintenance! Contact Billet Connection for more information or to order.
Billet Connection
mike@billetconnection.com
509-467-7584
NEW!! Push Rod & Wrist Pin Checking Tool ( www.billetconnection.com )
Re: NEW!! Push Rod & Wrist Pin Checking Tool
Postby Gator » Wed Apr 24, 2013 12:26 pm
Great looking piece.......
Users browsing this forum: No registered users and 0 guests
cron
