Pro streeting my 1966 Ford fairlane
powermadd
Postby powermadd » Sat Jun 12, 2010 11:18 am
Hi, i have a 66 fairlane with a built 429. I want to prostreet my car, but in the process i want to be able to keep my back seat. I'm curious how big of tubbs or tires i could use. I plan on putting a big blown motor in it and want to hook up. I also plan on running Coil over ladder bar rear suspension. I've spend hours online looking for other projects or info, and having troubles its either all out drag or as big as factory wheel well will allow. Looking for answers.
Re: Pro streeting my 1966 Ford fairlane
Postby draglist » Sat Jun 12, 2010 9:18 pm
Welcome to the board and good luck with your project. bp
Postby jim sanders » Tue Jun 15, 2010 6:57 pm
sounds like a job for Animal Jim
powermadd
Postby powermadd » Tue Jun 15, 2010 9:18 pm
Any tech support you could give me, i would really appreciate.
Postby Billy Mac » Wed Jun 16, 2010 11:04 am
Mini tubbing is prolly going to be your best course of action for keeping the rear seat intact.(although some "custom" tweaking of the seat may be in order) With that, you should be able to fit a ten to twelve inch tire and wheel combo under the wheel wells.
Good Luck with it and let us know how things are going... :arrow: 8)
Postby stimpy » Sun Jun 20, 2010 11:55 pm
if you really want the room forget ladder bars and go 4 link and mini tubs as the ladders will need some up and down room and unless you mount them pointed down at the front they aren't going to get the clearance they need
powermadd
Postby powermadd » Mon Jun 21, 2010 6:26 pm
Thanks for the info, if anybody has any other helpful advice i like to know what all my options are before i begin.
Mrs. Stimpy
Postby Mrs. Stimpy » Tue Jun 22, 2010 12:01 am
if your doing it yourself makesure the frame is well supported in a minimum of 8 places and level across all planes
Users browsing this forum: No registered users and 39 guests
