16 Volt Batteries
Mike-Casella
16 Volt Batteries
Postby Mike-Casella » Wed Feb 07, 2007 11:52 am
My poor old Turbostart 16 volt batteries are at the end of their life-span. I must replace them with something. I've been doing a ton of reading over the past month or so, about the different manufacturers of them now. It looks like the new light-weight 16's from Powermaster has what I need. Is there anyone else running 16's that may have different experiences?
I need to go with two due to the voltage draw that 8 nitrous solenoids produce in a 1/4 mile pass. Not to mention the other things like trans brake, etc.
Postby Lippy » Wed Feb 14, 2007 12:28 am
Mike, what about putting a mag in the car for the engine, get it off the batteries, run a retard deal for the mag, and run a oddyssey batt -12 volt for the rest.??Just a thought. That way the eng is on the mag, current would not affect the engine at all. Like a pro mag?
Mike-Casella
Postby Mike-Casella » Wed Feb 14, 2007 5:47 pm
I just don't have the room for a magneto. I need at least one 16volt battery just to keep up with voltage draw from 8 solenoids being on.
Anyway, everything is under control now, I didn't realize I am the only one running these batteries.
Postby Gator » Fri Feb 16, 2007 3:04 pm
You need that MSD For Sure!!!...16 volts ROCK Baby...
There is a new co. now Mike...
do a search?
on PRI website?
Postby Gator » Fri Feb 16, 2007 3:06 pm
batteriesaerus.com
lots of others
search 16 volt racing batteries
Postby jim sanders » Fri Feb 16, 2007 3:21 pm
:roll: I wouldn't be surprised in the near future that some of the hy-brid 24volt cars become high up on the most stolen lists :twisted:
Postby Gator » Fri Feb 16, 2007 3:42 pm
for 16 volt racing batteries?
Postby jim sanders » Fri Feb 16, 2007 4:27 pm
.... no just for the engineering..... 1 battery and 1 altenator.... capacity...seems logical ?
Postby Gator » Fri Feb 16, 2007 4:36 pm
start a thread then
i keep going here based on the title
16 volt batteries
for racing
Postby Billy Mac » Wed Feb 28, 2007 10:03 pm
Mike...just a thought here....based on your statement "not enough room for a Magneto"......is there anyone who makes a front drive system for a Mag, like MSD does for a regular distributor???...and if not....with your fabricating skills could YOU make one???
Users browsing this forum: Amazon [Bot] and 3 guests
