Compression ratio from compression test?
TurboDiverArt
Postby TurboDiverArt » Thu Sep 13, 2007 10:59 pm
Hi All,
I have what I think is a relatively simple question. Although I know not too accurate, I’m trying to get an idea of the compression in my engine. I just bought the car turnkey and have not really done much with it other than take it to the track a few times. I know the engine was originally built to run on methanol so it’s got some compression in it. I did a compression test on the engine while hot. The numbers across all cylinders were between 220 and 230 PSI. Can anyone give me an idea of what the effective compression ratio is?
Thanks,
Art.
Art Paltz
230" Undercover, 468ci stock block, 7.840@170.14
Postby greenracing » Tue Sep 18, 2007 8:45 am
Since C/R is based solely on volume calculations, and the compression test numbers you get are based on how well things are sealed up, I don't think that you can reliably convert from one to the other.
Postby SLICK VIC » Wed Sep 19, 2007 12:41 am
You would need to know the specs on the motor.
cylinder head cc, piston dome cc, deck ht,
gasket thicknes & diameter, bore, stroke..etc.etc..
So if you ever tear the motor down and find the info
listed above use this link below to figure your C/R
http://www.fuelinjectionenterprises.com/compression.htm
TurboDiverArt
Postby TurboDiverArt » Wed Sep 19, 2007 5:52 am
I definitely agree you there. I just want to try and get a general idea if possible. The engine's running great so there's no real reason to tear it down.
Art.
Art Paltz
Postby greenracing » Wed Sep 19, 2007 8:10 am
Then the CR must be 'just right' 8)
Postby pro70z28 » Wed Sep 19, 2007 8:13 am
can you find out who built the engine? Follow the paper trail backwards.
Postby stimpy » Wed Sep 19, 2007 7:46 pm
you could do it the nascar way and pump the motor or fill the cylinder up with a fluid to measure the volume at tdc and bdc , but the hard part is getting all the fluid out it would be a guesstamite .
Postby Eric David Bru » Wed Sep 19, 2007 10:17 pm
Are you sure that isn't CID not compression ratio?
Postby jim sanders » Wed Sep 19, 2007 11:16 pm
I'M WITH Mr.Green.. run it unti;ll you take it apart.
Postby stimpy » Wed Sep 19, 2007 11:18 pm
compare the volume at tdc vs the volume at bdc should give you the ratio and yes its a way of checking cid too but you use total volume .
Users browsing this forum: Google Adsense [Bot] and 10 guests
