Oil Brand & Viscosity
Mr. Monte
Postby Mr. Monte » Wed May 07, 2008 12:53 pm
Guys, I was just curious what brand and viscosity oil you all are using.
Nobody wins alone. Jimmy
jed5161
Postby jed5161 » Wed May 07, 2008 1:28 pm
Aspirated BBC- 20w50 kendall gt1 racing
Supercharged BBC & HEMI- cool to warm day, 50w kendall gt1 racing. mod. warm to HOT day, mix 50/50 of 50w and nitro 70 kendall gt1 racing.
Jared Micetich
Top Dragster 5161
www.myspace.com/jed5161
Mr. Monte
Postby Mr. Monte » Wed May 07, 2008 2:14 pm
Thanks Jed. I've been using 20-50 Brad Penn, and someone suggested that you actually pick up a few ponies by using a synthetic oil.
jed5161
Postby jed5161 » Wed May 07, 2008 4:16 pm
we've tried a few synthetics over the years. Only success we've had is tearing up cylinder walls and pistons. did that a couple times with different brands and just went back to what works for us. I always figured it had to do with the ol sayin of never break in a motor with synthetic oil, use regular and with the low amount runs we put on drag motors, it was the same as breakin it in with it. who knows
Jared Micetich
Top Dragster 5161
Big Erik
Postby Big Erik » Fri May 09, 2008 12:01 pm
I run Kendall gt1 50w used to run pennzoil 50w but the kendell is easier for me to get never had any troubles .thats said my buddy swears by mobil 1 synthetic??......I do run synthetic gear lube seems to help the life of the ring gear??.....ERIK
I'm everything they say i am......I'm so bad......Baby i don't care!!!
Postby stimpy » Sun May 25, 2008 12:12 am
when we ran superstock we used mobil one ,but we would run the motor in for a hour to break it in before any dyno time or track runs to get the rings to seat
Re: Oil Brand & Viscosity
Postby Eric David Bru » Mon May 26, 2008 1:15 am
I think the answer is "it depends"...
In our case, we drop the oil out at the end of each event, be it 3 passes or more...
With the Top Fuel car, we drop it every pass (of course).
In both case's we run Brad Penn. In the past the T/F car has run Amalie and Torco with no problems.
If you are running a carb'd gas engine, I would go with synthetic.
