New here, 350 not running right
Jack60
Postby Jack60 » Mon Jul 14, 2008 4:29 pm
New here I have a 1960 Corvette not much stock. It's a 350, Brodix heads and intake, MSD 6AL, Blaster2 and Pro Billet mech tach drive dist. 750 double pumper. Rev chip is 7000. The problem is just not running right from 4000 rpm , sounds like it is hitting rev limiter but rpm's still will climb just sounds bad. I have Accell 8.8mm Silicone Plus grafhite wires. After resetting timing [ 10* btdc hookup vacuum and have 34* advance ] setting idle, rev motor and get a good shock off of plug wires. I shouldn't get a shock [ like grabbing a plug wire ] from touching the side of the wire :roll: . Plug wires are at lease 3 years old.
Any ideas will be appreciated.
Thanks Jack
Have a driver.
Postby jim sanders » Mon Jul 14, 2008 5:07 pm
8) cool car and welcome.. i would check engine to frame and engine to battery grounds... add a couple fresh ones..
Postby Gator » Mon Jul 14, 2008 5:14 pm
plug wires could be contaminated....
new set of spiral core moroso wires..good
crank trigger? (if so..the transducer (pick up)
Postby draglist » Mon Jul 14, 2008 8:32 pm
Welcome to the board, Jack. Good luck with your issue. We got the guys here to answer the questions. bp
Jack60
Postby Jack60 » Thu Oct 23, 2008 10:28 am
Found out I wiped # 4 exhaust cam lobe. :shock:
Have a driver.
Postby pro70z28 » Thu Oct 23, 2008 1:18 pm
That will do it too. :oops: :oops: Sorry about the carnage. :cry: :cry:
Welcome to the board Jack.
Users browsing this forum: No registered users and 14 guests
